Hello all,
Firstly if you finish reading this, You deserve a cookie!
Finished my first water-cooling build last week (29/08/11) which is the following:
EK Supreme HF Full Nickel CPU Block
EK-FC580 GTX+ - Nickel Plexi Waterblock
Laing D5 Vario MCP655 12V DC Pump
EK-Multioption RES X2 - 250 Advanced
XSPC RX480
XSPC RX240
All was running excellent was very pleased with the results. Overclocked my i7 2600k to 4.7GHz with a random fixed vcore of 1.35 just for testing purposes which I will be soon lowering to find the lowest stable.
The temps was pretty good imo (54,57,60,55) on 100% load. My GTX 580 was maxing out on 100% load at 40c which was also excellent as it was reaching 87c on air.
As I said I was very pleased with the results of my first water-cooling build, Until the next day I noticed a very very small minor leak coming from under the port of the RX240 rad, It was a very small leak I checked it with a torch and noticed around the port there was a very fine opening where XSPC didn’t weld it correctly. So I partly drained my loop and took out the dual rad and got it RMA'd (which I must thank welsh Tom and Paul(XSPC) for the excellent speedy RMA, Dispatched a new rad the same day)
I got my new rad Friday and put the loop back together, I did re-use the fluid.
Now here is my problem, The temps I was getting before I partly drained the system and put the new rad in was CPU(54,57,60,55c) and GPU(40c) now I have the system re-built and with the new rad and re-used the fluid temps are now CPU(60,64,66,62c) and GPU(47c) that was last night's testing.
As you can see the temps have increased by around 6-7c, Now I was thinking this could be just room temp difference but I don’t think it is as 6-7c is quite a difference in room temp.
Do you think somehow when I re-used the fluid it could have got a few little bits in it and has clogged up somewhere in the loop? Which is causing the temp difference since I’ve re-built the loop.
Here is a screenshot from when I was testing before I changed out the radiator.
Here is a screenshot from last night with the loop re-built with the new radiator.
And today I’ve ran prime95 and the temps are around the same as last night all but 1c which I would account for room temp difference.
What do you guys think could be the cause of this temp difference since I’ve re-fitted the new radiator, Do you think it could be something in the loop that has clogged a little?
I don’t fancy taking the whole loop apart and cleaning right now, If you guys think it could be something in the loop that has clogged can it do any damage if I left it until I change the fluid in around 3months time?
Also do you think these temps are about right for my setup?
Many thanks in advanced for your help!
XSPC RX480
XSPC RX240
then put back in the original mayhems bottles and was on the side for a while then I put it in a dark cupboard.
