Temperature Monitoring in Raid Array Help
6 May 2010
hi there
i was stress testing my pc the other day and noticed that the internal case temps were quite high, when checking inside the case i found the hard drives to be very hot. I ran speedfan and HDDlife to check the temp but the software couldnt tell me. HDDlife said '2+0 stripe/RAID0 temperature monitoring is not supported'. I have 2 seagate 500GB hard drives set up in raid 0 using a M4A79XTD EVO mobo. Is there any other programs i can try? I assume its not working because its setup in raid and wondows sees it as 1 drive but i could be wrong. Any help would be appreciated, Thanks
You could try Everest, HDTune, HWMonitor, HWinfo
But I am not certain if any of them support temp monitoring of RAID setups.
