Lysander said:What would be REALLY good would be if someone could write a CPU temp gadget for the sidebar.
Latest version of speedfan 4.32 works fine in Vista x64,I can vouch for thatgizmoy2k said:one of the updates release by M$ yesterday sorted out some compatibility issues, Speedfan was 1 of the progs named although i havet tried it yet...
x64. still doesnt work![]()
>mcwildcard said:Coretemp works fine on Vista x64, I use it myself.
( as seems to work fine in xp 32) . It freezes exactly @ the time it loads hdd temps ( smart).snowdog said:Speedfan gives same problem as everest, freezes my pc and hdd light is stuck on, I'm startign to believe these apps hate my ite atapi ide cotnroller my 2 hdd's are on in 64 bit mode( as seems to work fine in xp 32) . It freezes exactly @ the time it loads hdd temps ( smart).
Speedfan working fine here on 2 x64 systems. There is also a sidebar gadget for it, have a look on the neowin forums![]()
