Hi, I have a problem with high temperature, the computer idles at 50c-55c after about 30 mins and any load it shoots up to 70c-80c and shuts down. It will idle all day at 50c-55c (maybe a little lower) but once the temperature goes up it takes hours for it to come back down. I have a Jeantech aqua case with a 12cm intake fan, 8cm exhaust fan and a 8cm side fan over the hsf (the hsf is spinning at 2000-2100rpm). I have taken the hsf off many times to reseat it using AS5, temps never get any better or worse. I have checked the cpu for concave IHS, seems ok, no worse than other cpu`s I have. Everything is running stock.
Please could I have advice what to do next? should I add more fans? I have no idea what to do.
Thanks.
Thanks.
