Sorry I should have been more specific, basically I'm thinking about attaching it to one in the side of my radiator which isn't being used for the fittings and tubing as 2 other ports are being used, that should still be fine right?
Thanks
You can also get sensors that have their own in and out. I.e they sin on the tube and allow fluid to pass through unrestricted. This is a good method for accurate intube temps.
