- 23 Nov 2014
- The Cronx
The 4 front fans are intake, and the rest are exhaust (2x 120mm case fans) and 2x Static Pressure 140mm radiator fans.
Since fixing the inlet / outlet on the 3090 I'm seeing max GPU temps around 64c with 3dmark on loop. The CPU still hits 90c almost immediately on Cinebench r23 but the boost speeds are strong (4.55ghz) and a multi-core score of 22500, which seems about right. I'm using PBO with -15 curve.
I guess I could drain the loop (COMPLETE PAIN IN THE ARSE) and re-seat the CPU block. Might even be worth checking contact on the GPU too. I just hate draining this loop and re-filling.
Unlucky, that's one of the reasons I avoid hardline (plus it's more difficult to do of course).
. With the GPU being vertically mounted I had to squeeze my hand between the bottom rad and the GPU and try to disconnect the power cable header or face a full drain just to reverse a tiny cable.
