Temps
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
I have a AMD 3800 X2 939 socket
Under fully load at stock my CPU is 36degrees, Motherboard 42degrees and HDD at 41degrees!
What temp should I start to worry for the motherboard when overclocking??
Thanks
I really wouldn't worry too much about motherboard heat - average airflow through your pc is fine for the motherboard to cool itself - even better if you have a dedicated motherboard heatsink/fan assembly.
Your CPU really shouldn't go above 60c so it looks like you have plenty of headroom there.
