Temps
30 Dec 2004
Bromley, Kent
Hi all,
Does anybody here run a Q9550/Q9450 in a V350 with a scythe mini ninja?
I'm a bit concerned as the CPU is topping out on one core around 74 - 75 and the others around 69 - 70 (Prime95 running on all cores). I know due to the size of the case it will run hotter, but I am still concerned its too hot. Obviously there isn't a lot I can do really, and there is very little chance of maxing all cores out for a very long time, if at all but I was wondering if anybody else had any feed back regarding this?
Thanks
- Pea0n
Mine E8600 was hitting that on watercooling. I had to get a bigger case in the end as it was a total pain to work on and i couldnt push my rig properly as temps were soo bad.
Thanks for that. Gaming-wise it doesn't go much above 60 - 65 so I can live with that, just happy knowing its not just me
- Pea0n
