TeraStation RAID Error
12 Dec 2003
My TeraStation has had a RAID error for ages and has been working fine but in light of my main PCs hard drive corrupting I thought I should fix it.
According to http://www.buffalotech.com/knowledgebase/users/kb.php?id=10135&category_id=0&sid2=, to fix it I need to restructure the RAID array.
Now my question is this, on that page it says
"This means that the data on the replacement drive will be erased, NOT the data on user array."
But since I haven't actually replaced a drive, this error has just developed, does that mean my data will be erased?
My understanding of that error would be that if you have replaced a drive then it's going to format the drive you put in, in a manner just to let you know, and if you haven't replaced a drive then one could have died
or if the RAID has just generally fubared then it's going to rebuild, but assuming it's raid 1 or 5 or something then it should all have redundency on your data?
not very useful sorry :p
Its 4 disks running in Raid5, all 250gb (unformatted) each. The entire array is currently full at 695GB. So yes there should be some redundancy but I dont know enough about RAID configs to know if there is enough redundancy with raid5 to be able to restore everything if that drive gets formatted.
