Terminal prompt
it needs to be under 15 characters long, also turn off all sharing before changing.
Unless the machine is on a network and you need it to be correct for remote login.. I wouldn't worry.
you can change it in here
Cheers. I've just called it Mac. The machine travels with me as I'm always away from home with work. I never had a need to connect to it. I'm just confused as to why that original name was there.
