- 23 May 2005
- Hove
Is it throttling at all?
Richdog said:Lol lots of dodgy info in this thread. A 2.4ghz AXP IS a slow CPU by todays standards there's no two ways about it. It sucks for gaming compared to A64, just look at this mass of CPU tests and judge relative performance http://www.tomshardware.com/2005/11/21/the_mother_of_all_cpu_charts_2005/page28.html
The 7800GS should be faster than the 9800Pro though anyhow, and I note you have changed from an ATi card to an NVidia one. One word: reformat. Twice I have changed from ATI to Nvidia and twice I had shoddy performance until I did a clean install. It should always be done when changing vid card brands imo and I bet if you did you would notice a boost in performance.
Also make sure you are running higher res with more detail so that the GPU is used, or you will be CPU-limiting it even more than it already is.
If I were you i'd upgrade to an Asrock 939 SATA2 board that has both the AGP/PCI slots and get a cheapish Skt 939 Venice, you'll notice a world of difference.
melchy said:Sorry an XP at 2.4Ghz isnt all that slow by todays standards. Where does the list you posted show overclocked XP's, the fastest i noticed was the XP3200+. I very nearly gave up on my first A64 setup (an A64 3500+) because at stock it was destroyed by the XP2500+ Mobile @ 2500Mhz that it was meant to replace. The XP @ 2500Mhz was faster than the A64 3500+ in everything i chucked at it, benchmarks, games. It was only when i clocked the A64 upto 2500Mhz as well that it really showed the XP a clean set of heels. In my case the extra 300Mhz that the XP had over the stock A64 3500+ more than made up for the A64's better architecture.
Richdog said:A 3200+ Barton is 2.2ghz... his CPU only 200mhz higher. I have overclocked and benched both AXP and A64 CPU's until I was blue in the face on all forms of cooling. 2.4 ghz is slow by todays standards compared to even a cheap A64, there's no debate.
If your 3500+ @ 2.2ghz was getting destroyed by an AXP @ 2.5ghz then you were doing something very, very wrong.
kdd said:no no no, an athlon xp @ 2500 mhz would be slower than a 2ghz a64.
melchy said:Sorry the XP @ 2500Mhz was faster than a A64 3500+ at stock in everything i tested it in. There was a big thread discussing the relative speed of overclocked XP's and A64s. whether it still exists or not i dont know. My system was at 2.5Ghz so faster than the 2.4Ghz in your link. I did have a few benchmarks both Sisoft Sandra synthetics and 3DMark05 benches for both machines but im unable to find them. They may still be linked in that thread. Anyway lets not derail this thread too much. My 05 and Sandra benchmarks for the A64 were spot on, so i wouldnt say i'd done anything wrong with the system.
Cyber-Mav said:also take into account that the xp1700 the OP is using is not a barton core which is a lot faster thanks to its larger cache. but a [email protected] is is still not too bad on processing power.
Richdog said:lol so it was 100mhz faster than the one in the benchies... it still would get demolished. I trust the review and benching system of a professional reviewer such as the guy from tech report to that of your own if you believe an AXP running 300mhz faster than a Skt 939 2.2ghz A64 CPU was genuinely faster, no offence. I have benched enough AXP's and A64's to know the difference, my AXP @ 2.8ghz was considerably slower in games and benchies than my Skt 754 @ 2.4ghz, and that was after fresh installs.![]()
my XP2500 (barton) at 2400mhz on a Nforce2 board was quiet a bit slower than my Socket 754 A64 3200 (2000mhz)melchy said:Sorry the XP @ 2500Mhz was faster than a A64 3500+ at stock in everything i tested it in. There was a big thread discussing the relative speed of overclocked XP's and A64s. whether it still exists or not i dont know. My system was at 2.5Ghz so faster than the 2.4Ghz in your link. I did have a few benchmarks both Sisoft Sandra synthetics and 3DMark05 benches for both machines but im unable to find them. They may still be linked in that thread. Anyway lets not derail this thread too much. My 05 and Sandra benchmarks for the A64 were spot on, so i wouldnt say i'd done anything wrong with the system.
