- 24 Oct 2002
- Portsmouth
Hi guys
In the last month or so gaming on my Virgin media 30mb cable connection has been near impossible.
Here is a snapshot of what my pings look like right now to BBC, a site with a healthy connection in London.
As you can see they're all over the place, and mostly rubbish. Packet loss also which means I can barely play games because of this.
Now the annoying thing is I called Virgin, and despite confirming the issue by doing pings from the superhub they still decided it 'could be malware' on my computer, but decided to send me a new superhub anyhow which arrives next week.
Has anyone had this before or have experience with poor performance like this on VM? They insist their network is fine and I'm highly doubtful a new Superhub is going to fix anything. Surely it will either work or it won't?
Pinging www.bbc.net.uk [212.58.246.95] with 32 bytes
Reply from 212.58.246.95: bytes=32 time=142ms TTL=53
Reply from 212.58.246.95: bytes=32 time=281ms TTL=53
Reply from 212.58.246.95: bytes=32 time=202ms TTL=53
Reply from 212.58.246.95: bytes=32 time=37ms TTL=53
Reply from 212.58.246.95: bytes=32 time=70ms TTL=53
Reply from 212.58.246.95: bytes=32 time=195ms TTL=53
Request timed out.
Reply from 212.58.246.95: bytes=32 time=363ms TTL=53
Reply from 212.58.246.95: bytes=32 time=95ms TTL=53
Reply from 212.58.246.95: bytes=32 time=182ms TTL=53
Reply from 212.58.246.95: bytes=32 time=149ms TTL=53
Reply from 212.58.246.95: bytes=32 time=102ms TTL=53
Reply from 212.58.246.95: bytes=32 time=159ms TTL=53
Reply from 212.58.246.95: bytes=32 time=130ms TTL=53
Reply from 212.58.246.95: bytes=32 time=303ms TTL=53
Reply from 212.58.246.95: bytes=32 time=291ms TTL=53
Reply from 212.58.246.95: bytes=32 time=325ms TTL=53
Reply from 212.58.246.95: bytes=32 time=236ms TTL=53
Reply from 212.58.246.95: bytes=32 time=379ms TTL=53
Request timed out.
Reply from 212.58.246.95: bytes=32 time=193ms TTL=53
Reply from 212.58.246.95: bytes=32 time=232ms TTL=53
Reply from 212.58.246.95: bytes=32 time=21ms TTL=53
Request timed out.
Request timed out.
Reply from 212.58.246.95: bytes=32 time=93ms TTL=53
Reply from 212.58.246.95: bytes=32 time=81ms TTL=53
Reply from 212.58.246.95: bytes=32 time=55ms TTL=53
Request timed out.
Reply from 212.58.246.95: bytes=32 time=35ms TTL=53
Reply from 212.58.246.95: bytes=32 time=18ms TTL=53
Reply from 212.58.246.95: bytes=32 time=111ms TTL=53
Reply from 212.58.246.95: bytes=32 time=151ms TTL=53
Reply from 212.58.246.95: bytes=32 time=24ms TTL=53
Reply from 212.58.246.95: bytes=32 time=99ms TTL=53
Reply from 212.58.246.95: bytes=32 time=98ms TTL=53
Reply from 212.58.246.95: bytes=32 time=119ms TTL=53
Reply from 212.58.246.95: bytes=32 time=145ms TTL=53
