Thats the old waysteve258 said:Stress Prime 2004
Put it in 2 different folders then run both at the same time with one set to Core 0 and the other one set to Core 1.
If one of the cores is not working properly the test will usually fail within seconds or minutes.
If both run for hours without error then your system is perfectly stable.
Final8y said:Thats the old way![]()
Get this Johnny Lee's Orthos http://sp2004.fre3.com/beta/beta2.htm
which is Prime 2004 but with a better interface & dual core instance built in.
FrostedNipple said:problem
look at your other post where i spook about acpi multiprocesor pc, its probabl not your cpu, when did you install windows, before geting the cpu, or at the same time as installing the cpu, or after
beast said:I don't think it is the CPU, the 945 Wasn't performing properly either that I had before (just for two days, didn't do these tests)
I have just used the same hard drive that I had in my old setup (xp2600) onto this new rig, with no format or anything like that.
Why, could that be the problem?
