TF2 Multicore
12 Jun 2007
Ireland
How much of fps boos did u get ? i got extra 50 fps
note: u will loose fps if u create server and be alone in a server. try to check in full server.
to enable it go in video advance settings
March 18, 2009 - Team Fortress 2 Update Released
Updates to Team Fortress 2 have been released. The updates will be applied automatically when your Steam client is restarted. The specific changes include:
Added Multicore Rendering
- This initial release is aimed at testing compatibility, so the option is OFF by default
- To turn it on, go to the Options->Video->Advanced dialog, and check the "Multicore Rendering" option
Other Changes
- Several performance improvements to decals and client bone/flex setup
- A variety of alt-tab and mode switch fixes
- Improvements to the way the engine initializes surround sound, fixing some specific hardware cases
- Fixed a crash on exit in Vista 64
oh awesome, well ive just given it a quick go. my maximum FPS seems to be 10-15fps lower with the multicore rendering enabled but my average fps is higher when involved in a large firefight :cool:
Interesting, it was already enabled on my machine :P
Hmm need to try this out more but ive just given this a go while using mat_queue_2 gave me perfect performance, i have been running without it for a little while. And now just tried this multicore thing and i see my fps going slightly lower than before (when i was on the normal cpu settings ie none) as i saw it dip as low as 20 when before it never went that low. Going to have to have a play around with this over the weekend, especially since my new monitor is in the post :D
Then again it does say in the update info, that it is for testing purposes at the moment.
When it wasn't in the options yet and used the console command I saw a reasonable boost, it also added crashes however... Would be steering clear of it, TF2 runs well enough anyways.
