Moar werk ! Today the drill bits finally came, along with the hole punch (works brilliant but too small punchouts
) some modding supplies, a fan splitter, and some other things I have forgotten.
Any way, last night I designed a revised IO panel along with 2mm hole marks. The reason I used Bradpoint bits is because they have a point that will follow a pilot hole making sure everything is straight.
So I cut a new back panel cover graphic from titanium. Sadly there are a couple of marks on it from where the blade has marked it but I wasn't about to pay £6.50 for something at the back.
I then cut another one out of scrap for drilling with.
And masked, cut out and applied it where the old one was.
And peeled off the masking. It's a bit of a two and eight but whatevs, only needed it for drilling.
And drilled.
Teh back.
OK so to get the final cover on perfectly I put a ruler down and basically cut out the old one.
Apply.
And build.
Back, noticing my careful placement of all of the grounds.
Now thankfully I can fit the RCA wires onto it without it being in the case, and then all I have to do is solder on the speaker tabs and bolt them on once it's in.
