- 17 Aug 2003
- Woburn Sand Dunes
38c load on a dual core that puts out nearly 70watts of heat? whats the efficiancy of that heatsink? im smelling a misreading sensor there
Maybe, still I'm impressed with it, apart from having to lap the base. Massive surface area and it pushes a lot of air. Loads temps dropped 10C from late 40's changing to this HSF. I've got a thermistor epoxyed to the base. Reading about the same range (under 40C) and the 20C delta from cold is correct and in line with the external sensor, it idles 8c over the case. Case temps only just above ambient (18C). Also the temps from the older HSF now on an ASUS board are similar late 40's. Either way its still 10C better than a Hyper 6 that weighs in at a solid 1kg of copper with 2x80mm fans running at 5000RPM.james.miller said:38c load on a dual core that puts out nearly 70watts of heat? whats the efficiancy of that heatsink? im smelling a misreading sensor there
james.miller said:you've got problems then.
opteron 148 cooled by a scythe ninja.
sagaboy2 said:you are right, I check the TIM and guess what Id left on the plastic film alllllllll this time.
Edit
24C idle @ 2.4 1.45v
38C load on both cores
