man_from_uncle said:It took be about 30 mins....3ghz with stock cooling on a gigabyte S3 with value ram...Only bought it a month ago, so I assume I received a recent stepping.
Fingers Crossed
[Delivery in progress]Matthew
[Delivery in progress]Scougar said:Unless your planning overclocking I don't really see any point buying a 2140/2160 however, seems a bit like buying an 8500gt, bit of a bum deal for average joe if he plays decent games.
Scougar said:Fingers Crossed[Delivery in progress]
Matthew
nlel1975 said:Good luck lets hope you get a good one and have no problems.... there are still some going about which do 3ghz fairly easily as the previous poster says but there are also the others which struggle to do 3ghz without loads of voltage...
man_from_uncle said:I don't know what a lot of volts is for these cpus, but I need about 1.425v to hit 3ghz (i might get away with less, but i've not had time to experiment). I'd probably be happy though to put anything up to 1.45v with stock cooling and 1.5-1.55v with top end air.
nlel1975 said:I regard 1.425v as a big voltage increase...
man_from_uncle said:Well I though initially i'd try it at a lower voltage to see if I could get it stable at around 1.4v. But almost as soon as I got into the BIOS I thought......why not go the other way? What's the absolute most I can get out of this chip? Life expectancy be damned.
I'm trying 3.15 at 1.45v doing Superpi32m to start with (I always use that as a quick indicator), but if that works i'll probably just trying creaming the thing. If I can get 3.4+ at 1.55v I'll probably grab a Titan Amanda and let it fly.
PS Temps under superpi fluctuating between 52 and 55C.
