** THE BEST USB HUB EVER?? SAMSUNG PORT DUPLICATOR ** - BUY NOW!!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
We have just recieved these fantastic port duplicators made by samsung. They essentially turn any USB port on your computer or laptop in a hub housing a mass of expansions. 4 x USB 2.0 of which 2 are powered!, a VGA that displays 1280x1024 (perfect for projectors and presentations), a RJ-45 with a 10-100 connection speed as well as a serial port, mic in and audio out!
Check it out for yourselves, this thing is rather HOT! :D
Special price ends 4pm on Tuesday 9th!
Samsung Port Duplicator with VGA, RS232 and RJ-45 ** SPECIAL PRICE ** @ £19.99 inc VAT
The Samsung port duplicator provides additional ports to your existing computer by using just 1 exisiting USB port!
- 15-pin VGA supporting max resolution of 1280x1024 at 16bit
- Two 3.5mm Audio: 1x Stereo out, 1x microphone in
- RS232 Serial
- RJ-45 Ethernet 10/100
- 2x USB 2.0 (white)
- 2x USB 2.0 Power Ports (Black providing up to 1AMP)
- 1x Software/Driver CD
Power and USB to host provided.
Requires a USB 1.1 to function however USB 2.0 is required for smooth video functionality.
Windows 2000 SP2 and above, Windows XP SP1 and above, Windows Vista and Windows 7 are supported.
Was £29.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
What can I use this for? I feel as though I can do cool things with it.
Essentially if you work at home you could have a monitor set up with keyboard and mouse etc ect all plugged into this. You then can plug this into your laptop and use as a desktop without having to worry about USB ports, plugging things in and out etc and it gives an extra display so you can run the laptop display, a second via the laptops vga out and a third with this. Unplug the suingle USB2.0 port from the laptop to take away with you on business. Job done :)
Its also very good to use as a business tool for connecting to projectors etc for slide shows and presentations.
At the very least it expands your ports on your machine for very little cost making this an absolutely bargain for what it is :)
Very nice, should be good for those that have older serial devices that they need to work.
Wonder if it could be used as, well some kind of KVM switch.
Plug into whichever computer you want keyboard, mouse and visuals from. Audio too maybe.
Pity it isn't usb3 i think it would be quite slow if used with external hard drives attached to it.
Why would you attach an external hard drive to this, rather than just using a normal USB port?
Can anyone say if these will work with Windows 7 64bit? I'm participially interested to know if the VGA output will work with 64bit.
Can you confirm that RS232 will work over this USB connection?
It would be brilliant to plug this to a laptop and forget the expensive docking station (got 1, need 2nd one now..)
Lol, 64 bit support???
Sat at a 32bit system with flawless prformance but couldnt say for 64bit I am affraid. Theres are people who havent got it all working on some OS but what that is and how they have it set up I couldnt tell you.
For the price they are a bargain though and the perfect companion for the office or home office.
