This would work extremely well with the FE 3080/3090 cards then. Interesting concept that actually works, wonder if in time it will become a more mainstream thing. Only problem is gpu's are all different widths and lengths so its not a 1 size fits all.@montymint Nice. I guess for this to work with GPUs they must have a gap at the top to let the hot air out, as that one does. Otherwise exhausting all the hot air through the meagre rear vents might prove difficult. Especially as most heatsinks have sideways instead of lengthwise-oriented fins these days.
If you ever get round to it and remember, I'd be interested in seeing some pics and results.
Was thinking this, wouldn't be too difficult to upscale or downscale the model to fit a different product as you wouldn't need to change anything else anyway.Yes I don't think it'll be feasible to mass-produce a one-size-fits-all either. If it takes off in the custom enthusiast arena you can bet some who have 3D printers and are handy with modelling will be uploading files for all sorts of different GPUs, though.
You could probably try this in the O11D as well, 3 x 120mm fans at the bottom with a large enough pcie space below the gpu (provided you use the top slot). Bet temps would be pretty cool!Imagine a case which allows bottom fan placements, i.e. PSU in an atypical location (Fractal Torrent springs to mind as one of the few new options for that) and funnelling the air from 2x140s directly and solely to the GPU. I wonder if that would blow what James did in the video out of the water, or if there are diminishing returns.
Ineresting, did you use any velocity stacks to smooth out airflow? Seen a few videos of these being used, like a weird experiment for cooler air as its rushing in at a higher velocity.Am I the only person that runs ducting from my front > cpu cooler > exhaust?
I did something similar to the video for my PS4 Pro so that the cool air was being drawn/forced from the front.
I've been using ducting for the CPU for a few years. Here's the most recent one: https://forums.overclockers.co.uk/threads/ducting-case-fan-to-cool-cpu.18916895/Am I the only person that runs ducting from my front > cpu cooler > exhaust?![]()
