- 6 Sep 2016
Any tips on how to sort that out? Case doesn't have section behind motherboard to route cables under.
Buy new case that has room or spend many hours with cable ties.
As above, not much you can do really as the case doesn't look to have much routing support.
Lots of cable ties and maybe some tubing cables like the following:
I checked OCUK's website and they don't appear to sell this sort of thing so it should be fine to link, but if I missed anything apologies in advance!
Pretty much. If you check the reviews there's a guy with pictures of his pc using them to give you an idea.Is that similar in principle to radiator lagging? A tube that's slice along the length then you put all the cables inside the lagging?
I've bundled up the unused beige cables out of the way so looks a bit better.
Don't think it's possible to get it as neat as new cases
