The Minimum specs for tekkit
30 Nov 2012
I have just been told that the minimum specs for tekkit is an i7 and 8GB of ram and a high-spec GPU, now even with my pc I could play tekkit, host the server and render and edit videos comfortably and the most RAM I have ever been able to use is 5GB EVER, even my old athlon 64 with 2GB of ram and a sapphire X1950 pro can run minecraft on on full, some people have no idea. But then again this is the person who thinks the 660 will be in date for TEN years.
tekkit isn't the best optimised thing in the world, hardware that can keep the likes of skyrim going at 60fps [that's with a LOT of mods btw] can't keep tekkit with high texturepacks going at more than 40, but that's not a hardware problem.
tbh, if you're fine with dealing with vanilla textures you can run it on basically anything.
also, more ram isn't nessecarily better for tekkit, I find speccing more than 4gb gives insane loading times
Yeah I know all this. Its just this guy who thinks he is the god of pc. A friend wants him to build a pc for £1200 and he speced the 660 as it was one of the best GPU you can buy and will be for 10 years
