The right channel of an Asus Essence STX II 7.1 card sometimes no longer works after the PC is rebooted.
5 Dec 2024
Switzerland
Hello everyone,
The right channel on my Asus Essence STX II 7.1 card sometimes refuses to work after rebooting the PC. I've checked the 2.1 system connected to it, including the cabling, and it works fine. The sound from the motherboard is good too.
Initially, this happened once every 3 months (I cold reboot once a week, the PC is on 24/365), then it became more frequent, about every 3-4 reboots. If the reboot goes well, I've never had a problem afterwards... until the next reboot.
There was no progress after reinstalling the STX_II_8_1_11_5_win10 driver.
As I assembled the PC myself, I had no trouble opening it up and checking the board, its power supply, cables and soldering, as well as the components. Everything looks good, but I'm not a connoisseur.
The PC was assembled in 2019 and I'm using Windows 10 Pro v1903 (no update since). The motherboard is an Asus TUF Z370-Pro Gaming.
After 10 months of wrestling with this, I've run out of ideas.
Thanks in advance for your answers.
Possibly one of the relays not working, IIRC this model has relays to swap between headphone and speaker output - if it happens try swapping the output device between headphone and speakers and back again and see if that results in it working.
Thank you very much for your answers.
Are they stock or upgraded?
These are the original amplifiers.
Do you mean that I connect the 6.35 headphone output into the 3.5 mini-jack cable that goes to the system 2.1 using an adapter? No risk of damaging the electronics because of a different impedance or level?
No - there should be a software option to change output between the different output modes - I've not used one in awhile so can't remember the setup.
I have this on the interface, unfortunately in French; this would be the setting marked Sortie analogique?
Yeah, if you swap it between earphones (headphones) and 2 speakers in theory it should activate the relays if I'm recalling correctly, you should hear a click coming from the soundcard itself. If the problem is a sticking relay on startup then changing mode should re-activate the relays.
I know the STX had relays I assume the II does as well but been awhile since I had a play.
Okay, I'll do that the next time it happens and I'll come back and give you the details. As this is an intermittent fault, it will take some time.
Anyway, thanks for the quick replies.
Hello boys and girls,
The right-hand channel gave out for good on December 15.
As the relay seemed to go well with noise, I changed the 3 OP amps on the main board on December 18 and the right channel worked again.
I have cold rebooted this PC six times every week since then and no worries.
Thanks a million for the precious help.
