Maris piper or desiree make good mash, peel it completely quatar it and leave it soaked in water for a little bit, this will leech some of the starch out.
When cooking it give it plenty of water so non are poking out of the boiling water, when you can easily push the BACK of a bread knife through they are ready to mash, drain the water and put the spuds back into the warm pan you just used to boil them.
Mash them!
now when fully mashed grab yourself a wooden spoon, add a little milk and butter sprinkle of salt and pepper, trick here when folding it is not to overwork the mash or you risk making cement!
Happy cooking
stev.
Get a ricer, cook Untill Just about falling to bits and do not stir to much. Starch releases and takes the fluff out.
Also once drained, allow to steam dry, to remove water.
Put plenty of butter in them and get a raw egg and beat it and then pour some of it over the potatoes add some salt to taste and pepper and mash .![]()
Retard question: Use ricer before or after they are cooked?
After.
Peel potatoes, cook till almost braking apart. Drain, leave in colander and allow to steam dry for a few mins,rests though ricer. Add butter, salt and plenty of pepper stir as little as possible.
Can also rinse potatoes before hand to help leech out starch, but I don't bother.
How many potatoes should I use for two people, and how long should they roughly be boiling for?
Lets ask someone who actually knows eh;
http://www.channel4.com/programmes/how-to-cook-like-heston/4od#3284267
From the 5:50 mark or recipe here
http://www.channel4.com/4food/recipes/chefs/heston-blumenthal/perfect-mash-recipe
You can't get smooth mash with skin on.I usually don't bother peeling because I am lazy.
Is the mash really better with peeled spuds?
