http://test.metrix.co.uk/
Ok, so boredom causes re-design.
What do you think?
Things I'm aware of, trying to fix:
Any suggestions? Comments?
Cheers
What do you think?
- Content - I'm adding stuff all the time, I've just added a bit to make sure it formats correctly.
- Lightbox bug in IE, the overlay PNG doesn't show, even though the readme says its compatible with IE6.
- Navigation links are smaller in FF than IE. Not too fussed, as they still work fine, and look ok, just not as wide and tall as in IE.
- I haven't validated either the mark-up/css yet, I tend to wait until I have pretty much everything on there and make sure all images have alt tags etc before I make it live. But I don't think there should be any major errors.
Cheers
). Don't take my opinion though, web design is all very subjective and something I don't like could be something someone else loves.
