The witcher cave wall bug
9 Sep 2007
There appears to be a bug in this game with the new patch 1.2
the wall in the cave chapter 1 where the boy is standing that he tells you to break down ,wont brake no matter how much Aard you use !
It seems to be common after doing a goggle search but no one appears to have an answer ,so if your thinking of buying don't bother !
Loading old loads dose not work either !
I wouldn't go that far. During my play through there were bugs but none that made me want to snap my disc in two. Every game has them, and its only on patch 1.2. For a game with that amount of depth many patches will be needed, hell most fps games go to 1.4 and beyond before everything is sorted!
You don't seem to understand that the bug stops you progressing from chapter 1 making it a very short game !
Also it has happened to people before the patch !
Played fine, hasnt crashed on me once, its not like gears of war i found it perfect to play with only the occasional jagger in framerate, exceptional game.
I played it through twice and had no problems what so ever. Every time i thought i found a bug i was pleasently surprised that i was doing something wrong and there was a totally logical explaination.
Maybe reinstall the previous patch? I play it through on the 1st patch no problems.
