- 20 Jan 2005
- Whitley Bay
Hi there.
Just moved house and set up my network again.
Consists of cable modem connected to Netgear WGR614v6 then an iMac, MacMini and laptop with Vista all connecting via Wireless (also a few consoles but they shouldn't matter).
iMac connects to the network fine and signal is strong as does the laptop.
The MacMini is in next room and although it did initially work fine is now failing to connect to the network with the error in the thread title.
Tried rebooting and resetting the router and it does now connect intermittently but the signal strength is showing as much lower than it did originally.
I'm on 10.4.10 on both Macs - I hear there are some issues with airport on this version?
I've tried deleting the WEP password from the keychain and setting it up again as well as deleting the Netgear network from my preferred network list and letting it setup again but still no better on the Mini.
FYI the Vista laptop connects to the network fine when sat next to the Mini.
Any ideas?
Thanks
Si![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Any ideas?
Thanks
Si
