Area will get larger regardless, as the contact area with the beaker increases.
You're right, but is the beaker a better insualtor than air? If it is then does this have much of an effect? If it's not then how much effect does it have then? If it's equivalent to air then does it have any effect at all? Either way it seems to have a small bearing on the outcome.
My main point is the 4th power of the temp difference is the largest factor at work in the scenario and the remining variables seem relatively negligible in comparision.
) to be parallel to gravity etc, then surface area is constant, volume increases, and now mixing earlier will keep it hotter than mixing later.
