thermal paste nightmare
Agreed, it's working and hasn't shorted out. If it was going to it would have failed straight way. Leave it well enough alone and stop worrying. ;)
Cheers guys - Yeah I'm just going to leave it alone now.
One last question, when I initially dropped the CPU it picked up a bit of a scratch on the left lip, took an image on Google to explain:
A tiny bit of the silver surface scratched away from it but alls this does is protect the underside of the CPU anyway I think?
Thanks
Anyone know if that scratch will likely cause me any problems down the line? :) Seems to be that the silver 'topping' has been removed a tiny bit and you can see a kinda copper underside.
No problems whatsoever. Infact some people (lap) sand down the IHS (top side) to improve temps by making it flatter/smoother.
As long as you haven't got chunks of the stuff embedded in the chip side then it will be fine. I also got a little bit on the pins and just slowly wiped it off with a spare spectacles cloth. :)
It's really not easy to destroy a CPU by handling it, you'd have to create some harsh static charge to damage it. A finger print worth of thermal grease won't be conductive enough to bridge anything.
That's what I thought. :D
Just concerned me a bit with it being on the side part though and not the actual top of the CPU.
Cheers
http://i.imgur.com/Q2uQS.jpg?1
Thanks
that scratch comes from the flip lock of socket also have those in my cpu
