Thanks for the replies, what kind of cloth should I use? Lint free?
IPA/isopropyl alcohol/isopropanol is likely used in industry for lots of cleaning.Are you sure it's safe to use on the underside of the chip? I don't want to be shelling out a couple of hundred quit after finding it out it irreparably damages the chip.
You could say: When there's problem, there's always solution to it.If only you knew how nonreactive gold is. You could probably clean it with acid.
