- 29 Aug 2010
- Cornwall
These days I tend to use AMeCh SGT-4, MX-4 or what came with the cooler depending on what I'm feeling at the time.
At some point an elderly person will suggest AS5 even though it hasn’t won any benchmarks for years.![]()
I must admit, I did try to buy this straight away when I built a new PCHa I must be elderly! While I’m not going to recommend AS5 as such I will say that I just used it recently and given that it’s been sat in my Fridge for about a decade it still works perfectly well
I was surprised it wasn't the claimed champ anymore
but then I've tried whatever came with a HSF ever since, and nothing made any difference in terms of a brand beating another.
Agree I think its likely to be such a minor difference between brands and compounds as to be irrelevant, application thickness and technique probably plays more of a factor. Certainly I cant see changing it will do much to drop my current 27oC idle temp on my 10600kI must admit, I did try to buy this straight away when I built a new PCI was surprised it wasn't the claimed champ anymore
I think it's a fad personally, and nothing is better than the other, not in a % that will actually benefit anyone enough to care, and lets face it, it's just thermal paste, so all the brand loyality is pointless, it's not like you can show it off![]()
Definitely! I agree that you'd be more likely to see placebo results from the application trying to replicate it exactly how you just did it, or as you say from various different techniques
I concur. Other than complete dog **** TIM, the key differentiator is applying it correctly versus everything else.Agree I think its likely to be such a minor difference between brands and compounds as to be irrelevant, application thickness and technique probably plays more of a factor. Certainly I cant see changing it will do much to drop my current 27oC idle temp on my 10600k
I have found on AM4 for example, that an X isn't as effective as just spreading it out nicely with some patience with a credit card or blade. The temps definitely reflected so, as I had to repaste it, and the latter method, yielded better results.There is no correct application method, past using as little material as possible. Everything depends on the mating surfaces between the hot and cold side as to how much of a temperature gradient can be achieved. The ideal case being two immaculate clean, completely flat pure copper surfaces in an inert environment. The best TIM is zero TIM as anything you sandwich between the two surfaces is acting as thermal insulation compared to copper.
That ideal case is ridiculous. No retail CPU and cooler are going to be remotely close to that scenario. This is why TIM exists. Show us your perfectly flat surfaces in an inert environment without TIM on your home desktop. I'll be waiting.There is no correct application method, past using as little material as possible. Everything depends on the mating surfaces between the hot and cold side as to how much of a temperature gradient can be achieved. The ideal case being two immaculate clean, completely flat pure copper surfaces in an inert environment. The best TIM is zero TIM as anything you sandwich between the two surfaces is acting as thermal insulation compared to copper.
There is absolutely a method of applying it correctly. Using the right amount (not spreading it all over the CPU socket and making a mess for no reason) and ensuring even pressure is applied at the end. Sure, you could debate the amount of paste, how to spread it, what the ideal mounting mechanism is, blah blah blah. That doesn't mean there isn't a general consensus on a reliable and repeatable way to cleanly mount a cooler with TIM. Keep it clean, mount it evenly. Simples.
