Thermal Paste
Permabanned
10 Aug 2006
Scotland
Would i notice a big diffrence from my cheap thermal paste and then to go Artic Silver i have currently lapped cpu i have noticed idle temps are good but when go to stress it, it gets hot a lot quicker?
barrymacp said:
I have saw a thew posts about it that some people have noticed a big diffrence like 10c lower.
I'd guess at 5 degs max TBH, a lot has to do with mounting and how well you've done this, Even with the same cooler if you balls up the application of the paste then you may even see temps go higher.
If the temps are worse after lapping then did you also lap the heatsink and try re-mounting using less and then may more paste to see which way the temps start going.
