What's the best thermal paste to use on my overclocked i5 3570K to reduce the temps as it's been 3-4 years without changing and should I use the pea size method or alternative?
^Good advice. The key thing is to use the correct amount, too much or too little will negatively impact cooling. Somewhere between the size of a BB pellet and a small pea works in my experience.
Out of these thermal paste, which one should I go for? Arctic Cooling MX-4, Arctic Silver 5, Noctua NT-H1 or Gelid GC Extreme as I will be trying to push the overclock with good temps
I still have the same tube of Arctic 5 I used for several builds over the last 7-8 years, served me well but a friend recently sent me this link of tested thermal pastes. Seems they are not all created equal, I'll be changeling brands for my new build.
After applying thermal paste and reseating the cooler, should I run stress test software to let the thermal paste settle in? If so which software should I use?
You say that, and of course you're right, however....
I always run a PC (Just at idle) for a full 24 hours to help 'bed things in' - Done it for years! (After doing an OS install)
