Ello,
I've just bought a Thermalright ultra-120 (to use with a new e2160) and I Installed it sideways (so the fan is mounted on the top or bottom of the heatsink.) and attached a fan to the bottom blowing cold air through the heatsink into the psu and out of the case.
I thought this would be a good idea, but It seems my temps are a little high, At idle im getting 39-41C and 50-52C under load. I've seen a lot of other people who have almost 10 degrees cooler.
Would it be a good idea to twist the heatsink 90 degrees so the fan is blowing out to the exaust fan in my case? Also, It's the first time i've applied thermal paste and read about people saying to use a rice grain sized blob of paste ,also another way which is to make a thin line of paste in the middle of the contact patch. I tried the line of paste and I'm thinking that I've applied a little too much paste, so would a rice sized blob be sufficient for such a big heatsink?
I've also heard about lapping, I think this is where the contact surface of the heatsink is concave (right word?
) and people sand it down until its nice and even. Is this a big problem with thermalright-120's or should I not bother?
Cheers
) and people sand it down until its nice and even. Is this a big problem with thermalright-120's or should I not bother?Cheers
