Thermaltake Case - Untidy!
I just noticed... is that a Q-tec PSU?!
Keep the case, remove most of the fans as they probably aren't needed but buy a new PSU if that is a Q-tec.
Why do you have so many molex's? Is it because the PSU has only a few molex's and you're using splitters to get the required amount?
Mines bit of a mess, but all molexs are pushed to the very bottom of the case, under the drive modules.
Just noticed Q-tec PSU as well.
i dunno why, lol i just plugged everything in as i thought i needed to! im a n00b at this stuff, yeh its a q-tec that a bad thing? lol
guess i shouldnt be using it for my new conroe system next month.
It's really not recommended, no. ;)
The only time it might supply it's rated power is in heat when it explodes. :|
Its because the Thermaltake fans use molex passthrough cables to connect the Hardcano fancontroller. That case also has a silly amount of case fans. Remember kids, the more the merrier is not true when it comes to fans. I think 2-3 120mm fans is sufficient for any system. If the case needs more than that, then its a badly designed case.
ok,
so should i be ok to still use this case for overclocking if i remove some of the fans a neaten all the wires up etc?
Or would you recommend buying a new case.
RickyDVT said:
ok,
You should be ok once its neat. But ultimately you should be looking for another case, even if just to make it look better.
cheers,
i did think mine looked quite good at first with all the blue led lights on it,
once its stripped down ready for new system, if i show you what fans are where, could you tell me which i can remove, as i dont wanna remove the important ones!!
oh Messiah, your a god! just been reading your case project, looks sweet man!
i thought as well, once ** case cosmetics where finished, just imagine the sheer beuty of the thing if u got RB Customs to airbrush it for you!!!
would be fantastic!
