ThermalTake cases
I dont like the ones with doors on them as the door is always in the way so had to take the last one off my old case.
Thanks for letting me know that, if for some strange reason I consider buying you a case I'll bear that in mind. That is if I don't ask my wife to slap me to bring me to my senses first.
My first ever case was a thermaltake tsunami dream, what a mistake. The build quality was very poor, cheap plastic pci card clamping system, (i had to remove it and use screws), rubbish stock fans that didnt have filters, it rattled like crazy and the panels were very flimsy. Stopped using it and bought an akasa eclipse 62, (excellent case), subsequently moved my rig into a Lian Li A70F as i wanted a bit more room.
Well i've been swayed far, far, far away from TT now.
Currently i'm looking at the Antec DF-85, is this a pretty good case for most needes? It seems to have a lot going for it.
Really? Damn... right back to looking at more cases then, thanks for the suggestions. I will report back with my new findings ;)
Edit: i've looked and seem to like the look and feel fo the Cooler Master HAF-X, anyone got any negative feedback about this case?
Mozart for the win.
:D
