thermaLTAKE LEVEL 10 GT
28 Nov 2004
i have a thermaltake level 10 gt and want to change the 200mm side fan.
will this be a big improvment.
BitFenix Spectre 200mm Fan - Black
Dimensions (mm): 200x200x25mm
- Current (A): 0.33A ±10% Speed (RPM): 900 RPM ±10%
- Air Flow (CFM): 148.72 CFM ±10%
- Air Pressure (mmH2O): 1.26 mmH2O
- Noise (dB-A): 27.5 dB(A)
and will it fit..
From the reviews i have read, it is just a normal 200mm fan, so any 200mm fan on the side can be fitted.
As for improving temperatures, i thought the stock fans were pretty good. I would have the panel open and see if the temperature changes much, if it does, more airflow would help. As for whether the spectre fans will help, it depends if they are a lot better than the stock fans (tbh, i doubt you will see big improvements).
It will fit but I'm not sure if it will be controllable by the button on top.
As for a big improvement, i doubt it.
