I bought this case the other day. I also ordered 2 TT Riing plus 200mm fans for the front.
There are mounting holes at the front of the case so no problem. Or so i thought.
The 4 holes for the lower fan are pre threaded, unfortunately the screws aren't long enough to get enough bite on the threads.
The upper 4 fan holes have no thread at all to screw in to!
I have no idea what the size of the screws are so i can see if i can buy some longer ones with a nut at the back.
I can't think of any other way around it, can you?
