Hi all.
Just finished building my first custom rig.
I built my first pc in college in 2001 and kept the xaser iii case changing just parts since then. I moved to a ps3 for gaming for a while then back to pc gaming on a 3xs 7970 laptop as I travel a lot for work and needed mobility. It's now changed for an Asus gl502vs.
Due to VR and sim racing I decided to get a new pc in October last year which I just sold tp a friend after having decided on a new case and cpu which morphed into a whole new water cooled build. I did start off with a Titan xp but when the ti came out I sent it in for a refund due to it basically being marginally slower for near double the money.
I am now in the process of looking at a couple of uv strips for the glass and tidying up the odd cable. It could also maybe do with a couple more thermaltake pacific rgb tubing fittings as the uv pastel white coolant does not transmit light well as i suspected but i like the look and also want some uv to bring out the white braided cables and fluid in the tubes / reservoir.
I'm sitting currently on a 5ghz cpu oc and the 1080ti is over 2ghz / 12ghz gpu / mem. The whole lot now needs a proper stress testing but I'm not sure what software to use as I've never properly oc'd before.
I did respray the case and the radiator with Ford frozen white and I clear coated with uv stable clear and added pearl pigments but due to Scottish weather it fogged a bit and i ended up sanding it back so I will re paint the sides and re clear coat them in the summer.
Any suggestions on a couple of nice uv strips for the top and bottom and what I can do to brighten up the psu a little? I did want a thermaltake rgb psu but good reviews dictated a seasonic one. I also braided all the cables.
Cheers for looking.
Cheers for looking.
you can't feed that back in the tube after a bend so you need to check your sizes after a bend before pulling out so to speak. If it's wrong and you have the silicone still in the tube and you apply heat slowly the tube starts to straighten out again. You may get the odd minor difference or it may not look spot on perfect but you can barely tell as long as you take it easy.
