Gashman said:its identical to the cooler im using, the blue orb II, except its red, thats the only difference![]()
Why would he want that?IceShock said:perhaps he wants a thermaltake?![]()
Joe42 said:Why would he want that?
As far as i know its rubbish, buy a zalman. Or even better, get a proper heatsink like a freezer or a ninja or a tuniq. They look good without needing to be painted red, and they work better too.![]()
easyrider said:Thats were you are wrong:
Its far from rubbish.
In fact its a great cooler that does the job well that is near enough silent.
The tunig is near enough 40 quid.
The orbs are not.
Suggesting that the orb is not a proper cpu cooler clearly shows your lack of knowledge in this area.
Have you used one?
Installed one?
Mointored cpu temps with one?
If the answers to these questions are no, then I suggest you stop spouting rubbish on these boards.
You can't really compare it with other heatsinks if you've replaced the fan.i replaced the 120mm fan with a difference one from an aerocool turbine
you could always buy an AC freezer and just buy some cathodes, or even a Zalman 7700CuTosk said:its to go in my sugo evo i was thinking of using blue and red colours to light up the insides
or i still might go blue and green not sure yet
using a stock cooler atm and its quiet nosy..
my m8 uses the blur orb and its quiet so i will be buying that or
the red orb
thanks for the posts guys n girls
