These Q6600 temps can't be right?
9 Jun 2006
Hi all
A couple of days ago I got a new rig. All is well now after a bit of playing with the RAM voltages but I have noticed that my Q6600 temps seem very low in the bios.
The motherboard is a MSI P7N 780i diamond and the cooler is the tuniq tower 120. The Q6600 is currently clocked at 3Ghz and i am getting idle temps of 25c and load temps of 28c after playing crysis for an hour. These temps seem really low to me so i'm not sure if it is a problem with the MB or if its normal.
Also forgot to mention that the case is the Antec p182.
Any idea anyone?
cpuz will tell you whether you q6600 is B3 or G0.
The newest coretemp will work fine in 64bit vista.
Speedfan isn't renowned for being reliable.
Right did some tests last night on this. The CPU is a revision G0 and it idles at between 28c-30c across the 4 cores running at 3Ghz with a 1.264 core voltage. At load it jumps to between 39c-40c across the 4 cores. That seems a little more normal.
So if the temps are as they are above what sort of overclock can I get above the current 3Ghz I'm running do you recon?
ok well I use HWMonitor for my Vista 64 for temps.
What do you class as load?
Prime would take it to it's max load.
You should be able to get up to 3.2 without changing volts or anything - that was the case with mine ; just check ram divider and make sure it's either 1:1 or slightly higher depending on ram you have.
