- 22 Sep 2005
- Manchester
If it aint broke... DONT FIX IT !
Or have good house insurence.FishPolice said:I remember someone on this forum once saying something like "if you can afford to replace all your kit in the event of a leak then go for water cooling -otherwise think twice".
I'd love to do it but I'm too scared lol![]()
instead, fix it till it breaksR B CUSTOMS said:If it aint broke... DONT FIX IT !
Just ordered itlay-z-boy said:instead, fix it till it breaks![]()
apex ultra btw, dont bother with anything else, it wont be anywhere near as good/upgradable and you wont regret it.![]()
pegasus1 said:True but a GFX card still probably produces the most heat in the case, especially if its an ATI card![]()
locutus12 said:dont generalise an entire manufacturer just because you didnt like a particular product at a particular point.
QUOTE]
Did you not notice the obviouse smily after a said that, I dont dislike any manufactorer, build good kit and i'l buy it, still got a 9800pro in a machine. 1900xt is a cracking card, and usefull if your central heating has stopped working![]()
