- 14 Mar 2011
Hello!
Having come to rely on the raspberry pi I've got sat under my TV but feeling like it is sometimes a bit weak, has problems here and there, looks messy etc. I've been thinking about replacing it with something more solid. Trying to avoid spending a fortune, so maybe around £200ish, anyone got any ideas? I was thinking of something like this:
YOUR BASKET
1 x Gigabyte H61TN Intel H61 (Socket 1155) DDR3 Thin ITX Motherboard £77.99
1 x Akasa Euler Fanless Thin Mini-ITX Case - Black £69.95
1 x Kingston 30GB SSDNow S200 Drive SATA 6Gb/s 3 2.5" (9.5mm height) Solid State Hard Drive - (SS200S3/30G) £39.95
1 x Intel Celeron G550 2.60GHz Socket LGA 1155 Processor - Retail £31.99
1 x Corsair 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz 204-Pin SODIMM Module (CMSO2GX3M1A1333C9) £17.99
Total : £249.26 (includes shipping : £9.50).
If my understanding is right then the thin-ITX boards have a built in DC PSU, and the Akasa Euler comes with an AC power brick which I could use to power it. It's not the most powerful system but I assume if I threw OpenELEC on there it would cope pretty well with its normal watching duties. However what would you say are the chances of it running any other basic things? (For instance some basic 2D indie titles on Steam, or other basic games/emulation)?
YOUR BASKET
Very good price, and also see my answer below for another reason I'm not bothered too much how good the drive is...
I jest, I don't really need any onboard storage because all of my media is on a separate server, so I intend to have this machine mount NFS shares to get its content. Also someday in the distant future I also want the server machine to have a couple of TV tuner cards in it and allow this device to connect to one of those streams (or schedule recording on the other) - haven't looked into the details of this yet but its a long way off as I don't have a suitable ariel/dish connection to the server at the moment
A full Linux distribution will be able to run 2D games with Steam, but if you switch to normal ITX, you could get an APU that will let you run games like Half Life and TF2 as well.
... I guess that Akasa case won't work with a normal ITX board? Know of anything similar that does? Maybe this?
Even the RPi seems to cope okay with fairly high quality stuff so long as it's on a decent wired connection to the server. Surely the Intel celerons should be able to cope? (I guess an APU would eat it up though)
- can never have too much RAM of course)
For gaming though you will want dual channel memory, so 1x2GB wouldn't be ideal.
... someday though!
