Right, get ready for this.
I got the arctic freezer pro 7 the other day and got round to fitting it just now, as i was waiting for Articlean to arrive. So, i turn everything off and take the mobo out ready to get going.
Cue 1/2 hour of consumate half-arsery.
Firstly, taking the stock heatsink off. I unfasten the bracket and pull the heatsink off relatively easily, only looking to find that the cpu is stuck to the bottom, and i tell you it was absolutely baked on, would not budge at all.
Ok, so i get the hair-dryer out and try heating it up. bingo, the cpu comes off with no problem.
Then, as i am holding it up to the light to have a look at it, (get ready for it) a pigeon flies in to my window making a massive bang almost scaring me to death and causing me to drop the cpu on to the floor, and fall off of my chair.
If you can imagine it, i could not find the cpu for about 10 minutes!!
Anyway, maybe it's gone over by the bookcase, ok i'll just move my shoes out of the way, hold on whats that rattling in my shoes?
I took out the cpu and it seemed ok. removed the thermal paste and put it back in the socket.
Then came fitting the new heatsink. Wow, that was a pain. Had to push down really hard to get it fitted worrying all of the time that i was forcing it too much, but aparrantly they are not that easy to fit on amd boards.
I have everything up and running now and everything seems ok, it would appear that i have gotten away with it. (what if i had put my shoe on?)
I have 2 questions though.
1. My idle temps since i fitted it have gone up slightly(not exactly worried but they should go down surely) from 25-27 with stock to 28-30 now. Does this mean there is a problem with the thermal paste maybe, or possibly the cpu surface? i really don't want to take it off again.
2. Is pigeon damage covered in the warranty?
