Thinking of overclocking my GFX crad even more - Safe?
12 Dec 2005
Hey guys.
Ive overclocked my 6800 128MB Graphics card.
I used Nvidias "Detect Optimal Frequencies" tab, and it overclocked the graphics card by its self. The default is : 325/700.
It is overclocked at : 386/821
Do you think i could take it any more?
If i could, how would be the right method of doing it?
And i dont wanna risk blowing it, i cant afford another one :p
Also, i know my card is only 128MB, but when i bought it, the man said it could be unlocked to GT. How do i unlock it to GT? Ive already opened the pipes (16) does this mean GT?
- Denic
Overclock it. If it blows up or what ever then back down the overclock. If it runs fine then just keep overclocking it until it blows up.
On a more serious note - just overclock it until it becomes unstable or artifacts.
3dmark 03/05 are good quick apps to run to test for artifacts etc.
So, if it blows up, i can reverse it? So it un-blows up?
- Denic
Got it to 400 on core!
Gonna 3D mark it in a sec.
Do i need to do anything with "memory clock frequency" ?
Thanks in advance.
- Denic
No luck.
Ran 3DMARK 03 and it decided to reboot its self in the middle of testing.
At least i tried!
Now its back to 386/821
Thanks
- Denic
Yeah thats the spirit! Maybe stick it back together with some sticky tape like blue peter would.
Or just pull another one out and say "luckily heres one I made earlier".
denic2k6 said:
Is this temperature level too high?
58 - IDLE.
If so, do i need another fan in my pc?
Only worry about temperature if your card slithers out of your PC in a liquid state.
Check the load temp if you can. Keep it under 85c.
