- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
Today I turned my PC on, it was running sluggish. Tried a few software diagnostics.
Nothing!
So I took the side panel off my PC to find this.....
WHITE FLUID ON MY GPU..... WTF!!! First leak in 2 years (never changed the fluid or fittings at all.
Anyway I turned the PC off sharpish....
I found where the leak was coming from.
Essentially the cause of this was my DDC pump failing, and as a result the CPU started to boil the fluid sat on top of it, to the point where the heat cracked the block and fluid started to leak over my 2 x GTX 780s.
Luckily I've stripped it all down now and fitted an Antec Kuhler 950 for now until I get new blocks, which I was planning on doing as soon as OCUK have stock arrive from XSPC anyway in the next day or two.
All going into my new Project: Flame orange PC.
Nothing!
