Those on 02 : What is this "FarEast" thing in my routers settings?
4 Feb 2004
Fife, Scotland
Using a Wireless Box II and have been having a few minor speed issues and connection drops over the past week or so. Had a rummage around in my router settings for the first time in ages and found in the Home>Home Network>Devices the following listing :-
What on earth is FarEast?. :eek: :confused:
I only have my main PC and an HP printer connected to the ethernet ports 1 and 2 on the back of the router, nothing is in Ethernet port 3.
Status: inactive would imply that its something that has been connected to port 3 and is still in the ARP cache. Its not an O2 thing
MAC address 00A0CC
Company LITE-ON COMMUNICATIONS, INC
Hmmm.
Well, this afternoon my connection started playing up and I disconnected the yellow cable from Port 1 which goes between the PC network connection port and the router and plugged it into Port 3 to see if it worked from there.
Could that be something to do with it?. I removed it and plugged it back into Port 1 as per usual and then my connection came back online about 30 mins later so it was most probably nothing to do with the router, more likely line/connection probs.
If you're unsure about telnetting to it, I wouldnt bother fiddling around in there. Its not doing any harm so I'd just leave it :)
