I think the hole at the front is there to frustrate you when you're receiving the attentions of someone else. It'd be more elegant to go out through the hole at the front, but when you're standing to attention it's near impossible unless you're prepared to near snap it in half. It may look far less elegant to just tug them down a bit, but it's much easier.
I just open my fly and hook my left thumb up on the top of my pants, then pull them down. It can easily be done wearing a shirt. It's hardly any distance from the top of the fly, and probably only an inch or 2 from the Y opening. The only way it would be more difficult or slower is if you wore your pants up at belly button height.
It's the same technique as if you were wearing briefs without the slot.
