- 23 Feb 2024
- UK
Hey all, I am a new user but long time lurker looking for some advice on my new build.
I am an experienced PC builder and have no worries about selecting components that fit and work together, but want to make sure I am not specifying something that will be a lemon for my two, seemingly opposing intended usage scenarios.
For my work I create enormous composite photographs and videos which requires a performant multi-threaded processor. The work scales linearly with threads, so the more I have, the quicker the jobs are complete. For a number of years I have used my first-generation Threadripper rig, which is decent for work, but absolutely sucks for gaming. I intend to use this system during out of work hours for gaming, and may even game while I wait for the gigapictures to stitch. Yes, I spend most of my time in a darkened room
. I am not worried about having "the fastest possible gaming system", but likewise I do not want it to suck and be a limit for the 4080 Super (or potentially 4090) I intend to couple it with. My questions are:
1. Is the 7995WX a reasonable gaming processor, given its strength for my work use, or is it going to have a load of performance issues like my current rig? I want to play triple A titles at full detail. No esports, ultra-high-fps required.
2. Is a 4090 a waste with this CPU (if it is CPU bound), and therefore should I get a 4080 Super instead? I game on a Samsung Odyssey 49" 5120x1440 monitor, and work on an 8K Dell UltraSharp UP3218K.
3. Can anyone recommend some RDIMMs that don't look like server RAM? I want this machine to look good as it is the centrepiece of my "man cave".
4. I am torn between TRX50 and TRX90 as a platform. RAM wise, 64GB x 4 will be enough, or 32GB x 8. For work, each core "likes" around 2GB of RAM, with any more than this not going to good use. I imagine 256GB of RAM will be enough for any game for the lifetime of this PC. Are there any pros or cons for going with 8 x 32GB vs 4 x 64GB? I've heard with all ranks populated the peak achievable clock speed and timings on the DRAM tanks for Ryzen due to memory controller load, which may counteract any benefit the extra channels yield. I imagine the same to be true for Threadripper but there is very little info on the subject that I can find. Budget is not really a consideration, but the TRX90s look a lot more "servery" than the TRX50s and I imagine will have similarly annoying server-like behaviour as the WRX80 they replace like long boot times, fan curves that require you to log into the BMC to edit, and so on.
Many thanks for any advice
PB
. I am not worried about having "the fastest possible gaming system", but likewise I do not want it to suck and be a limit for the 4080 Super (or potentially 4090) I intend to couple it with. My questions are:1. Is the 7995WX a reasonable gaming processor, given its strength for my work use, or is it going to have a load of performance issues like my current rig? I want to play triple A titles at full detail. No esports, ultra-high-fps required.
PB
