Three pin fan to USB convertor cable?
15 Mar 2005
Hello everyone, is it possible to get a three pin fan to USB converter cable (which would plug into normal USB receptacle socket?
Thanks
Yes it is. The fan though would need to be 5v or at least run at 5v, not a guarantee with all fans.
Indeed, male USB to female 3-pin fan adapters cables are readily available on web. What do you plan to do with it?
Well, you're are not going to like this, but I was looking into passive NUC type cases, the Akasa ones get good reviews. No real downsides except the m2/sata drives can run hot. So, maybe I could rig an external fan.
Completely unprofessional, but on-one will see it behind the TV
