OK, so we've had the 'how do I turbo my car' threads etc. How do you go about converting your NASP wagon for use with throttle bodies?
Speculation welcome but I'd prefer some facts too
So far, I'm thinking, inlet manifold comes off, TB's/injectors attach to head. The car I've got in mind is the Rover K series which I believe uses a MAP sensor for fuelling, so it will fuel based on manifold pressure but wait, we just removed the manifold!
Also, how is this done for cars with a MAF? Air is sucked in and metered just after the filter but now each 'trumpet' (I think that's the correct term?) so I'm not sure how that would work at all.
After market management... OK, we all know to get the most out of the engine it's always the best route but we aint talking forced induction here so I was thinking, perhaps, uprated the fuel regulator/increase rail pressure slightly to compensate. Perhaps along with injectors/fuel pump. Then, book an hour on a rolling road or someone who has a wideband lambda to make sure the fuelling is right and er, wham bam job done?
I suspect I've overlooked something major but please feel free to pick holes in my plan! This is possibly going to be my track car btw. It will most likely start life as a Rover Metro 1.4 16v. They're cheap to run/maintain, nice and light for slinging round the track and hopefully, not too hard to release some extra horses.
If you're sitting there thinking, WTF?! then the basis for all this is that the Lotus Exige used the 1.8 K series with throttle bodies and they made good power, circa 200BHP. Obviously, I don't expect anywhere near this performance from a home brew hybrid rust bucket but that's where the inspiration comes from
